Port matching? Intake manifold selection?
Old Dec 6, 2004 | 09:29 AM
ZD75blue's Avatar
ZD75blue
Can I do it with a dremel? Or do I need to use something with more power? (I've got some other grinders... not sure I trust their insulation though!)
Old Dec 6, 2004 | 09:35 AM
comp's Avatar
comp
it will take awile,, and it may ware it out but has been done Many time's
Old Dec 10, 2004 | 02:17 PM
djcwardog's Avatar
djcwardog
Granted that this is a test based on manifolds for a ZZ454 Chevy, but this magazine (Hot Rod) swears by the Performer RPM Air Gap. Read the story here. http://www.hotrod.com/techarticles/1...ld/index2.html
Perhaps you can do a web search and see if this info tracks over to the SB Chevy as well. By the way, to keep the stock hood you have few options for a decent manifold... I wonder if I should drop on a copy of the L-88 hood and use the L-88 air cleaner system so I can run that Air Gap myself...
