496 runs for first time...
Old Nov 12, 2004 | 03:02 PM
Doug Brandon's Avatar
Doug Brandon
Default 496 runs for first time...
Got it running and have cam broken in. Started right up with no leaks so far, except for a pesky exhaust leak on the left header flange. As soon as I get the inner valve springs back in, I will drive it and seat the rings. Looking forward to trying out the TKO500 trans.
Guess I need to update my sig, and post some pics!
Old Nov 12, 2004 | 05:55 PM
ZD75blue's Avatar
ZD75blue
Cool!
Glad everything went without a hitch (Except the exhaust leak... then again, thats headers for ya!)
Old Nov 12, 2004 | 10:56 PM
96CELT4's Avatar
96CELT4
Sounds like it will be a beast. I haven't been following along, could you give some details on the engine and what year vette it's going in?
Thanks!
Old Nov 13, 2004 | 12:13 AM
Doug Brandon
Default 496
Hope to get some pics up tomorrow. Car is a '71 that is in the process of getting painted.
The forum has been a big help with my tech questions. My goal was a factory LS6 appearance under a stock BB hood, but with better power. Motor has a 4340 Scat steel crank, SRP 10.2 to 1 pistons, GMPP alum heads, factory low rise LS6 intake, and a solid FT cam.
I have a Keisler modified Tremec 5 speed, Centerforce DF clutch and 3.36 gears. I will take if for a spin tomorrow. Should be a blast to drive once it is finished.
Old Nov 13, 2004 | 12:49 AM
Les's Avatar
Les
Congrats Doug! If I remember right you were cam shopping not that long ago- what did you end up going with?
Old Nov 13, 2004 | 11:57 AM
Doug Brandon
I spoke with Harold Brookshire and he recommended one similar to the 243/251 that a lot of guys on the Chevelle Forum use. He thought with my intake, I would be better to use a single pattern. Cam is 243/243 @050 with .586 lift on a 110 LSA. Has a nice sound at idle and crisp throttle response.
I have heard different lash settings for these cams. The book says .024 or .026. Not sure if that is hot or cold. I have them at .020 for initial start up. What lash are you running with yours?
Old Nov 13, 2004 | 07:54 PM
Les's Avatar
Les
The cam card said .026 but I lash them at a tight .024. I have plenty of low end as it is so I figure I'll set it up to soften that a bit & max out mid-range & top end. With your extra inches you'll pull real hard right off idle. PLEASE post pics or vids if you can- I'd love to hear that thing sing!
Old Nov 14, 2004 | 11:39 PM
Doug Brandon
Trying to upload a pic.
Old Nov 15, 2004 | 07:02 PM
Les's Avatar
Les
Looking good Doug. I like the color of the coating on your headers. Mine have the silver coating & they look nice but there's not alot of variety under my hood- aluminum/chrome tones w/ some orange showing from the block. What brand are the headers themselves? I'm curious because Hedman makes the only 2" primaries for our cars that I know of.
Old Nov 15, 2004 | 10:42 PM
Doug Brandon
Default Headers
They are Hedman headers. I had a shop south of Atlanta coat them. I like the look of the black for my car. The second tube needed a little clearancing for the steering gear.
I need to get those valve covers painted!
Old Nov 16, 2004 | 12:13 AM
Les's Avatar
Les
That's interesting- I have a solid 1/4" clearance on that tube but had to put a slight dimple on a passenger side tube where it was tapping the frame at idle. So, are the valve covers going to be Chevy orange?
Old Nov 16, 2004 | 10:17 AM
Doug Brandon
I know what you mean about the passenger side, mine taps a little there too.
The valve covers will be Chevy orange. I have 3 coats of primer on there now that I have been sanding between coats to get it smooth.
Old Nov 16, 2004 | 07:50 PM
Les's Avatar
Les
That's gonna look nice when you're done Doug. Now for the big question- how does that sucker run???
Old Nov 16, 2004 | 09:07 PM
Doug Brandon
Good so far, but have not gotten it out of the neighborhood yet. I am in the middle of installing the inner valve springs, and fixing a header gasket leak. Should have a much better answer this weekend. It certainly has a more righteous idle than it used to!
Old Nov 22, 2004 | 02:07 AM
Les's Avatar
Les
Doug,
I figure you've got the rings pretty well seated by now & have had a chance to get a better feel for how it runs- what's the verdict???
Old Dec 3, 2004 | 04:51 PM
Brettmc's Avatar
Brettmc
Be nice to hear it....
Brett
To 496 runs for first time...
