Broken crankshaft... Non corvette..57 Chevy
Old Nov 13, 2004 | 05:15 PM
Larry B.'s Avatar
Larry B.
Default Broken crankshaft... Non corvette..57 Chevy
I am a longtime C3 forum member. The question I have is: I have a friend who has a 57 Chevy with a 350/ th400. Today we discovered that the lower pulley,along with the balancer have about 25 degrees of TOTALLY free play. No resistance whatsoever. Even with a loose timing chain there should be some resistance from the internals (pistons) but this engine has none. The engine runs fine although I didn't drive it. Has anyone ever seen a crankshft nose broken? I suspect this is what we will find when we get into it tomorrow AM.. Very strange...
Old Nov 14, 2004 | 05:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sounds like the key in the crank broke, he does have one in there dosen't he ? and the balancer is spinning on the crank. If the crank was broke the balancer would fall off. I would not drive or start it like this because the balancer could fly off, very dangerous
Old Nov 15, 2004 | 05:47 AM
Larry B.'s Avatar
Larry B.
Yep... That's what was wrong. The keyway was 3 times it's normal width and the key was mangled too. A new key and balancer was the solution. Seems that "Bubba " had been at work.. the center bolt had SHOCK washers and a rubber cushion. Looks like it had been there for a few years. Thanks
Old Nov 15, 2004 | 07:20 AM
71coupe's Avatar
71coupe
I thought the 50's small blocks didn't have a ballancer bolt Glad they changed that
Old Nov 16, 2004 | 12:12 PM
Larry B.'s Avatar
Larry B.
You are correct... old 265's, 283's, and small journal 327's and 302's do not have a bolt.
Old Nov 17, 2004 | 04:29 AM
comp's Avatar
comp
that is crazy, no key-ways doesn't make sence to me
Old Nov 17, 2004 | 09:06 AM
SG4206's Avatar
SG4206
The 327s had key-ways on the nose for the crank sprocket and balancer ;just no crank bolt to hold on the balancer.
To Broken crankshaft... Non corvette..57 Chevy
