Removing valve retainers from installed heads...
Old Nov 13, 2004 | 10:47 PM
Doug Brandon's Avatar
Doug Brandon
Default Removing valve retainers from installed heads...
I have to install the inner springs on my heads. I have never done this before when the heads on installed on the engine. Is it just a matter of putting air pressure in the cylinder and using a spring compressor? Any tips on the process?
Old Nov 14, 2004 | 11:15 AM
Gordonm's Avatar
Gordonm
That is how I have always done it. Some times the retainer sticks to the keepers a little and requires a slight rap to free the stuck retainer. Just watch out for the keepers. They are small and can get into spaces you do not want them to go. I use a magnet to hold onto them while removing.
Old Nov 14, 2004 | 09:07 PM
SteveG75's Avatar
SteveG75
I just replaced my valve seals. All I did was rotate each cylinder to TDC in firing order and fed a little rope in as extra insurance. With the piston at TDC, the valve could drop maybe 1/2" maximum. Easy job. Took me about 5 1/2 hours to do all sixteen seals and I had never done it before. Agree with the magnet comment and remember to put some rags (clean) into the oil drain back holes to plug them before starting.
To Removing valve retainers from installed heads...
