Anyone using a CompCam XE284
Old Nov 23, 2004 | 07:38 PM
marshrat99's Avatar
marshrat99
Default Anyone using a CompCam XE284
I'm currently running a XE262 on my 355, 9.7:1CR, Dart 180heads. I have lots of torque and vacuum. Anyone using the XE284 and would I see any noticable improvements?
Old Nov 23, 2004 | 08:56 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Need a lot more info about your gearing, trans, how you drive it, etc.. While the 284 would definitely make more peak hp, if your car isn't geared for it you could wind up with less power where you actually use it. I'm happy with the XE274 in my 327, wide ratio trans, 3.36 rear but I usually recommend the 268 when asked for advice.
Old Nov 29, 2004 | 08:35 AM
LFZ's Avatar
LFZ
My 383 being built will have an XE284. From the opinions i've received..this seems like the cam to go with, especially from those with xe274s that want more power.
Old Nov 30, 2004 | 03:16 PM
tdelph's Avatar
tdelph
I am having my 468 finished and I will have this cam set up too. Let me know what you guys think after you get your done.
Old Dec 2, 2004 | 08:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
I used a XE284 in my last motor in my Elky-Dart 200's, 9.8-1, Team G with 4.11's and a T-56. To be honest with you, a 274 and a smaller head like you're running would have been a be a much better choice. Your motor should run hard.
To Anyone using a CompCam XE284
