From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes that is where oil originates and you want it opened up a little more
How did you measure the clearances ?
My first explantion was not very good, I do believe the explanation I got was that it handles more load especially on a 4 speed car so that is why you want it opened more to get more oil
My question is why is the large #5 location have different specs than 1-4? Shouldn't all the clearances be the same?
Any comments appreciated.
First, not to break any body's bubble, but the #5 main is NOT fed directly by the oil pump, even though it bolts to the #5 main cap. The oil passes to the side of the rear bearing, up to the oil galleys running parallel to the camshaft. The #5 main gets it's oil in the same manner as the other 4 mains.
*I* can't explain the production clearance differences in the main bearings. My Factory Service Manual shows, #1 and #5 as each being unique, and 2-4 as the same as one another. The Chevrolet Power book, makes no distinction to the position.
That's interesting CFI because 1 & 5 are noticebly different than 2,3 and 4. I notice from plastigauge on 5 that the bearing is so wide it smashes the most where the bolts are which is around .0025 but tapers out to .0035 at the fwd end. I think that's why the 69 manual gives a larger spec because they know there is no way to get an even distribution since the two bolts are to one side only.
I'm trying to decide wether to spend another $50 bucks to get another undersize(or oversize?) set and make everything perfect. My last engine has/had an issue with low oil pressure, so I want to make sure clearances arent an issue on this 383.
In would further like to calrify what I meant in my previous post as well as my opinion why the bearing in question is bigger that the others .
What I meant was "Yes" I agree with the previous post about that being the thrust bearing, next I elaborated on
this by stating that is where the oil originates for the the surface he is talking about. I can expand that even further : The rear main bearing is different from the other bearing in that it has a an extra surface that must be lubricated this area could be called the bearing flange. On the crankshft, in addition to the actual #5 (rear) crank journal there is an area behind this called the crankshaft thrust face. This area requires good lubrication because this is the area that stops the crankshaft from moving forward. In a 4 speed car this is even more important because there is more stress here as you bang through the gears.
With this in mind it kind of makes sense to have a little more clearance on this bearing to allow more oil to get to this surface.
Actually, the bearing has TWO thrust flanges. One for forward thrust and one for rearward thrust.
The actual "gear change" (bang through the gears) doesn't impart a thrust load on the crankshaft. Merely depressing the clutch pedal does. The thrust surfaces, may indeed, be the reasoning for the additional clearance on the #5 bearing, as that would allow more oil to pass.
Someone had intimated that the reason for the additional clearance was the proximity to the pump. I wasn't addressing anyone, specifically, in mentioning the oil routing.
Do crank journals wear just like a cam lobe? The rod journals... the rod applies force on the top, bottom... left and right sides of the journal through out the swing! I wonder if this would put the same kind of wear pattern on the journal, given the rotation doesnt switch directions...
Wouldnt that cause the rod to try and walk forward on the crank? Thrust front to back, back to front?
CFI, I layed the plastigauge in the fore and aft direction.
Rethinking, it doesnt make sense for it to taper even if the bolts are to one side of the bearing. Something must be causing the taper. I'll check for burrs.
The idea about needing more oil flow to the flanges sounds like a possiblilty for bigger specs. The actual spec for #5 is .0018-.0034.
The load on the rod journal changes, depending on the stroke it is on. The piston drives the crank down on the power stroke. On the other down stroke, the crank has to pull the piston down for the intake. On the two up strokes the crank is also "powering" the piston. On one to push the exhaust gases out and on the other to compress the A/F mixture.
Ideally there will little to no wear to the crank journals. You have a soft copper bearing surface acting against a hardened iron or steel crank journal. Lapses in lubrication and contaminants in the oil cause almost all crankshaft wear.
If the cylinder bores are straight and square to the crank centerline and the rods are true and straight, there are virtually no thrust forces on the crank from the reciprocating parts.
From: Las Vegas - Just stop perpetuating myths please.
Do the plastigage measurements repeat?
Originally Posted by Surfer69
I measured my clearances on my new 383 and here are the results:
FRONT------------------------------------------------------AFT
------1----------2--------------3------------4----------5
---.0030-------0.0018-------- .0025-------0.0025------.0035
'69 Manual Spec 1 - 4 ( .0008 - .0020 ) 5 ( .0035 MAX )
max service limit .0040
Plastigage does have a shelf life. Can u find this date? And to verify measurements can u repeat them fairly accurately? But if u keep getting the same numbers either run the 0.010" oversize bearings (heck even mix & match with 0.020" over brgs) or get it back to a machine shop.
Hey i can see ur gonna find out whats wrong if u have made this much effort to do it right. Just need to follow through here as most other repairs can be fixed with the block in the car. Yes details here will pay off in longivity or economicaly or maybe even more beach bunnies in the passenger seat with less time on jack stands.
Good luck. cardo0
But if u keep getting the same numbers either run the 0.010" oversize bearings (heck even mix & match with 0.020" over brgs) or get it back to a machine shop. cardo0
If he uses even one half of a 0.010" bearing in any position, the crank it going to be locked tighter than Fort Knox.
Not what i way trying to recommend.
RACE ON!!!
Yes that could be true using 2 different sizes of 1/2 brg on same journal but not what i was trying to say. For the 0.035" clearances a 0.020" oversize brg could get u back to spec while using the 0.010" oversize in another journal that has only 0.018" or 0.025" clearance. No, i don't imply to install a 0.010" oversize brg 1/2 with any other size brg 1/2.
Though i have never done this myself i recall Grumby Jenkins doubling brgs as spacers for the destroking of 400" mtrs to 377" (3.48" crank in 400" block) - by stacking 400" crank brgs on top of 3.48" brgs. I recall he also prepared them using something like Scotch Brite pads to smooth and final fit/size them.
But if changing brg sizes to correct clearance differences between journals would lock the crank up please explain. cardo0
First, using two closely matched but different sized bearing shells results in a clearance, close to their average.
At first, I thought it was just a typo, so I didn't make much of it. Since you reiterate, look at the post you quoted. Using the number five main clearance as measured at thirty five TEN thousandths (three and one half thousandths) as an example. Now subtract the .010" (ten thousandths) bearing you propose. .0035 - .010 = -.0065. *I* don't call an interference fit a "correct clearance". You think that won't lock up the crankshaft?
Okay i'm only off by a decimal place (or 2).
RACE ON!!!
My bad. :o I got the Chilton's out and see my error. Chilton's also has the same specs as posted and had a few paragraphs on measuring mn brg cleareance. Maybe this can help here:
- wipe brg dry, no oil
- Plastigage parrallel crank
- after torquing, measure p-gage at widest point and if flattened p-gage widens at middle or ends brg or journal has taper > then measure crank with a micrometer (but Chilton's doesn't elaborate how)
- use standard 0.001" & 0.002" undersize brgs to produce proper clearance > if fit too sloppy, then crank must be reground.
So i'm thinking that the undersize brgs (which i think really means larger/oversize brg to fill the gap) are the fix here. As u can tell i'm no brg expert but a good parts man (NAPA or maybe a auto-machine shop) can maybe find these for u. Anyways u will need to verify with p-gage again. And a little Scotch Brite can help smooth things out but be careful/conservative.
Now it's important to always check a crank for smooth drag-free rotation before closing up the surgery.
Good luck. cardo0
I had thought it might be a typo. We ALL make them. That's why I didn't say much, first time. Then, when you didn't understand what I was saying...
That is fairly intuitive. Measure the journal diameter in at least three different positions, along it's length. Once in the middle, and once, toward each end, looking for signs of taper or a barrel shape. These measurements should also be made at several points around the journal, checking for an "out if round" journal.
For really fine tuning, you can use a standard shell in the block and a .001" in the cap to reduce the clearance by .0005". The same can be done using a .001" in combination with a .002".
Yes. The crank is ground or worn undersized, so it takes an oversize bearing to make it fit properly.
