Polishing connecting rods?
Old Dec 10, 2004 | 09:54 PM
ZD75blue's Avatar
ZD75blue
Default Polishing connecting rods?
Polishing connecting rods... I read an article a few months back about cleaning up the edges of the rods, grinding off all that rough garbage off the sides of the beams. The article says that the weight is reduced, and any chance of stress risers from the rough stuff is cut down to slim to none.
Do you just grab a grinder and do it?
Old Dec 10, 2004 | 10:35 PM
SWCDuke's Avatar
SWCDuke
Prior to reworking you should have them Magnaflux inspected to ensure they are crank free. Then grind off the die flash, but the finish does not have to be mirror smooth.
Once ground down have the entire rod shot peened.
Just grinding off the die flash without going through the whole prep process is of little value.
Duke
Old Dec 10, 2004 | 10:41 PM
ZD75blue's Avatar
ZD75blue
Magnaflux... How much is this machine?
I've got a couple of engines that are in need of a rebuild... if the purchase price is a couple hundred bucks, I think I could find room in the shed
Old Dec 11, 2004 | 02:18 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Never heard anyone buying thier own.
I remember magnaflux uses a powerful electro-magnet and fine iron filings. But some training is involved to use and interpret aplication.
If u are able to build and accomplish this please post.
Good luck. cardo0
Old Dec 11, 2004 | 08:43 AM
SWCDuke's Avatar
SWCDuke
Look in your local yellow pages for a shop that does Magnaflux inspection or ask around at local engine builders who they use.
Duke
Old Dec 11, 2004 | 10:43 AM
ZD75blue's Avatar
ZD75blue
Looks like it takes a gollywhopper electro-magnet, a big ring for small stuff, a hoop for doing blocks.
The way it works for blocks: They've got a horseshoe type electro-magnet that magnatizes the block between the two contact points, and any cracks between those points cause the flow of electrons to freak out... making your magnetic powder stick to the crack. The powder is either iron filings, or magnetic powder that glows under black light.
For cranks, they have the big hoop, crank goes through the hoop, crank gets sprayed down with magnetic liquid, lights go off... any cracks show up as tiny little hairlines. Disreguarding stress cracks near the oil passages.
Rods, gears, other stuff... I havent found a picture/discription except for a program about Aircraft maintenace I peeped on TV. Again, a black room... making the part magnetic, and dousing it with green stuff.
With all that said, I havent been able to find any of these things for sale. I did find a picture of a "Kwik-Way" Astroprobe that was in use, but Kwik-way doesnt list anything like it on their website.
Old Dec 11, 2004 | 12:21 PM
CFI-EFI's Avatar
CFI-EFI
Unless you plan to make a career of this, I doubt you'll find purchasing the Magnafux and Zyglo equipment, cost effective. My recollection is that the fees for those service are quite reasonable, and often included with other services, like rod rebuilding.
CAUTION: Make sure any and all your grinding on the rods, is LENGTHWISE.
RACE ON!!!
Old Dec 11, 2004 | 04:35 PM
ZD75blue's Avatar
ZD75blue
Wouldnt be exclusively engine building...
Old Dec 12, 2004 | 09:36 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
another way to find small cracks in metal is to use a dye penetrant style kit... it doesn't show the deep down stuff but it has and does find the small surface cracks that you usually can't see with the eye...I get my kit from a weld supply store.
Old Dec 12, 2004 | 11:33 PM
ZD75blue's Avatar
ZD75blue
I'll look into that... thanks for the heads up!
Old Dec 13, 2004 | 06:40 AM
KyRP2NITe Corvette
Just so you know what you're looking for.
Three aresole cans.. first a cleaner..then a penetrant dye, you spray on wait a few minutes and wipe off the excess then use the third can of developer...what ever dye seeped into a crack will show up in the developer.... it's a pretty cool kit, neat when it finds a crack but then you realize your part is junk and it sucks LOL!
Old Dec 13, 2004 | 10:46 AM
comp's Avatar
comp
true ,But lot's better than after it let's go
Old Dec 15, 2004 | 01:21 PM
SKYCOP1's Avatar
SKYCOP1
Can you lighten H beam rods??
Tom
To Polishing connecting rods?
