more questions on 2x4 setup.
do both carbs need a choke
why progressive lnkage as opposed to a solid non progressive setup
do you need more then average fuel pressure
are both carbs jetted the same
how do you figure the CFM rating you need to use for the carbs
do both carbs have to be the same CFM rating, if using progressive linkage.
thanks
greg
Progressive much better for the street, if that is what you are doing.
Again, street can use stock pressure.
Yea, jet them the same.
Add the 2 for total.
You can, but only slight differences, jet to match. I would'nt do it.
