Need specs on Speedpro CS1071R cam
Old Jan 3, 2005 | 10:03 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Default Need specs on Speedpro CS1071R cam
My friend has a Chevy 383 small block with a Speedpro CS1071R, roller cam in his 1960 Corvette ( just bought).......... cant get it to idle smoothly.............it has 10 inches of vac at idle & idles rough , obviously its a high rpm camshasft & not a street grind >>> . any tech info on this cam will be appreciated...the Dog
Old Jan 3, 2005 | 01:11 PM
Ironcross's Avatar
Ironcross
Default CS1071R hydraulic roller cam
Cam series is Pro-5000. Idle quality is fair. Power range is 2500-6000. Duratuon at .050 lift 230-230, .006 lift is 306-306. Valve lift is 480-480. Lobe C/L 108 and overlap is 90
Old Jan 3, 2005 | 05:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
You won't get much vacuum from that cam, period. Should make that 327 scream with gears and a good set of heads. Nothing like a mean sounding C2
Old Jan 3, 2005 | 06:57 PM
StrayDog's Avatar
StrayDog
The engine is 383 cu in , stroker small block ,Brondix alum heads, 3.55 rear gears, ,,,,previous owner said best et was 12.86 @ 115 MPH
Old Jan 4, 2005 | 01:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Oops-skimmed through that a little too fast. 108 lobe center will make it pretty lopey (low vacuum). Spreading it to, say a 112 would make a night and day difference. Car may not "hit" as hard, but will have an extended, or flatter power band.
Old Jan 4, 2005 | 10:47 AM
comp's Avatar
comp
short on lift for those heads
To Need specs on Speedpro CS1071R cam
