Drilling steam holes
Old Jan 18, 2005 | 03:24 PM
GregP's Avatar
GregP
Default Drilling steam holes
The machine shop I usually use loaned out their jig for dirlling the head steam holes so I can't get them to drill my AFR heads (at least if I want to work on the engine this weekend while Julie is gone and I can evict her car from the garage). Anyone have instructions for drilling them, and could/should I undertake this without a jig setup? Alternatively, anyone know another machine shop near Annapolis MD that can drill them who I can call tomorrow to see if they could fit it in on Thurs or Fri?
Thanks - Greg
Old Jan 18, 2005 | 05:10 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Chevy power manual.
Pretty much detailed in the Chevy Power Manual. Usualy at the local dealer for <$25. cardo0
Old Jan 18, 2005 | 06:05 PM
GregP's Avatar
GregP
I have a bunch of SBC books (bunt not that one of course) and none of them show how to angle the holes, only that they are there.
-Greg
Old Jan 18, 2005 | 07:16 PM
comp's Avatar
comp
didn't know they are angled
Old Jan 18, 2005 | 07:24 PM
GregP's Avatar
GregP
Found two different refs on the web, and of course they show different angles. Maybe try something between ??
-Greg
Old Jan 18, 2005 | 07:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
SO they don't hit the water jackets, can't help you as I didn't do mine but the guy that did used the Felpro head gasket as a template and just angled the drill away from the water jackets.
Old Jan 19, 2005 | 07:56 AM
silver84's Avatar
silver84
Where does the steam go?
Old Jan 19, 2005 | 07:59 AM
LD85's Avatar
LD85
from the AFR website
13) 400 BLOCKS:
Steam holes are recommended for all 400 block applications. Use a 400
gasket as a template and drill the three holes nearest the spark plug side of the head straight down, the other three which are very near the head bolt holes should be drilled at a 30 degree angle away from the bolt hole. The center hole will intersect water about 1" down and the two outboard holes to a depth of 2 1/4". Use a 1/8 drill.
Old Jan 19, 2005 | 08:08 AM
GregP's Avatar
GregP
"Steam" is probably a misnomer. They are to make sure air bubbles don't get trapped in the top of the block water jackets since the jackets don't go between the cylinders. The holes connect the block to the head water passages.
-Greg
Old Jan 19, 2005 | 08:09 AM
GregP's Avatar
GregP
13) 400 BLOCKS:
2 1/4" is a long way with a 1/8 drill! I hadn't seen the depth anywhere else, and they didn't send that info with my heads (I didn't look at their website since it isn't mentioned in my catalog either).
Thanks - Greg
Old Jan 19, 2005 | 10:26 AM
CFI-EFI's Avatar
CFI-EFI
If they don't go into the water jackets, what's the point? That's a heck of a way to lighten your heads.
RACE ON!!!
Old Jan 19, 2005 | 12:54 PM
MotorHead's Avatar
MotorHead
You know I was just going to leave my post the way it was, I realized as soon as I posted I had it backwards,thanks for catching that, Im keeping an eye out for any mistakes from you
Old Jan 19, 2005 | 02:26 PM
CFI-EFI's Avatar
CFI-EFI
Is that addressed to me? Or to silver84?
RACE ON!!!
If you're talking to ME, you are going to be doing a lot of typing. I make TONS of mistakes. I correct the ones I catch, but many must slip past me. It will be comforting to have you as my proof reader, to keep me honest. Thank you.
RACE ON!!!
To Drilling steam holes
