Super Charger cam and compression questions
A 2-piece rear main seal to a 1-piece,center-bolt valve covers,the 4 inside intake bolts are more perpendicular than previous years.
I think that's it.
aside from 6 bolt mains, your major difference as "superstreet" mentioned is achitecture.
The cylinder heads placement of 15* vs. 23* of the Gen 1 motor's,the location of exhaust valves being similar to the big block design. (Notice pics of Headers on an LSX motor vs. Gen 1 motor).
Paul this is just an offering of info, as I'm just a Bigblock old school guy who has found deep respect on the power, and 1/4, 1/8th mile track times these LSX motors are capable of..
Having a 6.0 iron blocked, Aluminum headed LSX motor will be affordable, and the power adder's it will appreciate that you may add in the future are mind boggling.
Here's some cylinder head info. Not saying you have to use RHS products, just soak up the cylinder head design info.....
http://www.chevyhiperformance.com/te...ead/index.html
btw, several carburator type intakes for the LSX motors are available also.
I'm enjoying this thread Paul, and whatever road you and your boys decide to travel down on your build to more HP, I support you.
Definitely be watching this thread.
re: Superstreet's "Show a Pic of Your F-Body" thread!...
Thanks Gent....
"Hey superstreet",.....btw,
I finally went and did what you requested.
(See pics of one of my rides on page 4 of your thread).
I saw your "Popcorn" icon, but it had been so long, I don't know if you realized it was pics from the guy you helped with your suggestion
Thanks Gent....
I never put the two together,lol.
Which one is yours? I looked under your username and didn't see it
The boys and i are currently putting together a build list... should have it done in a week or so, and will post.... currently talking to the guy that does my porting, polishing, and port-matching head work to get his view of these heads and there potential in comparison to AFR, world, and a few others....
there will be no chines $h17 parts used.... if its not made in the USA... its not used.... unless no viable option is available...
Same as my C3:-)
p:-)
Same as my C3:-)
p:-)
Same as my C3:-)
p:-)
Same as my C3:-)
p:-)
Totally. A friend of mine who has 7 Mustangs in his stable (A couple Boss 302's, fastback,a couple Boss 429's,etc) bought a good set of heads and for some reason they came with Chinese valves. He checked one of the heads and fluid leaks past the valve. Crappy valve job on top of Chinese valves.
We do our best, not always successful, to buy USA made products when we can.
Generally, much better products, and we have to many USA workers out of work.... and that bothers me...
Another friend of mine was restoring his '69 Camaro SS and bought cheaper Chinese junk drip rails. They rails came up about 3/8" short by the time it came up to the windshield. He ending up returning those and spent a little more on O.E. parts. Fit perfectly.
Right under Corvette Mike's Silver Camaro?
my Red Formula displays by me, not by you?...
btw, Yes Great thread here. We all look forward to the build
#33
but it will be a very slow thread..... before the build, the boys got to sale there dune buggy the built.... they got it up for $7K... they built it themselves, ground up, when ask i gave some technical advice... thats all... looks like it came off a showroom floor, and they are 17 and 15yo.... very proud of them, they have listened and learned well....
#34
It would give us an idea of the expectation on the next build. What do you think Paul..coupl'a pics?
btw, Look in the sticky area on the Father Son Paintjob thread on their '80 Trans Am.
It started like yours, but with all the good postings of the project over time, put it permanantly at the top of this F-Body Forum....
#35
http://forums.corvetteforum.com/f-bo...-thread-4.html
#36
It would be wonderful for you to post a couple pics of the Dune Buggy.
the first pic is right after powder-coat...they did all the mettle fabrication also...they did start with a very basic rusted frame that someone gave them.... that is all the had to start with, and i do mean basic... it did not even have a dash of any type, what you see is there fabrication work... nothing... basic rusted out frame...
This is chris' jeep, a 72 he has been working on for 2 years... it was a compleat rust bucket before he started...
#37
Fast Stocker for sure superstreet!
I run, and am in the points in the Corvette/GM/etc. Challenge Series at www.racepbir.com. I run in "GM"
Driven 60 miles one way, It runs 11.90's/113 in cooler air. 12.0's in the heat and 12.1's in the dog days of Summer here in the SE Florida Heat. I weigh in at around 280lbs. When I go 11.90's, my 160lb. nephew has gone 11.80 the same day.
Stock 346 bottom end + Heads/Cam/Bolt-ons/Susp/3.73's, 3200TCI Conv./Masport Tuned, and on Nitto 315/35x17 Drag Radials.
Funny how you don't feel the Torque, like I did in some of my Square Port, Solid lifter old Big Block Bowtie cars, but these LSX cars run a number don't they?!
That's why I brought up here to Paul on his thread about a possible LSX combo.....
#38
"Holy Smokes!"........
ok.. you ask.... it took my boys 4 months to do this, they did everything themselves, only ask sometimes for guidance, but this is all there from the ground up... they are 15 and 17yo,,,, very proud of them.
Yea, You just gotta take us all here for a ride on their Camaro Build for sure.
#39
they think they will beat Baby (ny C3 vett) when they are done.... we will see,,,,
#40
