F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
2000 Firebird Won't Start
Old Aug 3, 2010 | 09:17 PM
Kenny94945's Avatar
Kenny94945
Default 2000 Firebird Won't Start
Posted Tues Aug 03 2010
V6 Engine - All Stock.
Battery fully charged....cables tight.
Lights do not dim when ignition key turned.
I hear fuel pumps (or engine noises engage) when key turned.
All other functions (AC, Horn, Interior Lights Radio) are functioning.
Just like no power to the starter.
I only have an owners manual and the one fuse (large square fuse) that says starter appears OK.
Any leads before I have it towed?
Old Aug 4, 2010 | 03:07 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Is the VATS ignition key correct for the car?
Old Aug 4, 2010 | 05:10 PM
Kenny94945's Avatar
Kenny94945
Thanks...yes that was a thought.
We tried the second key thinking the pellet may be flawed.
Still no start.
Towing to dealer as based on research and symptoms I am guessing it is the secury system.
Seems these cars have an issue with a broken wire inside the steering column.
If wire not repaired, new ignition cylinder assembly is installed.
Could be something else though.
Old Aug 6, 2010 | 04:40 PM
Kenny94945's Avatar
Kenny94945
Yes, broken wire from ignition key asy to harness, in the sterring column.
New ignition cylinder (comes with wires that plug into harness), two new pelleted keys.
All fixed...first time this car actually stranded us - we're original owners.
Marin County Calif labor rates - diagnosis then parts and labor @$550.
Old Aug 6, 2010 | 06:50 PM
leadfoot4's Avatar
leadfoot4
Glad to hear you're back up and running.....too bad it cost $500.
To 2000 Firebird Won't Start
