Now I have gone and done it! First gen Camaro goo roos step in please
I just picked up what I am pretty sure is a real 68 Z-28 Camaro, but as you know 68 is the hardest one to authenticate without the matching "MO" 302 engine.
However it has the original never been off the car rear bumper with big bumper guards (z28 only) Rear end was built the same month and week as the car 3.73 12 bolt posi with 4 leaf multi (4 leaf is z28 only) has factory holes and hangers in rear frame rails for dual exhaust (z28 was the only dual exhaust small block???) M-21 trans and still has the Muncie linkage, and shifter. Power disc brakes,(all Z 28s had this) manual steering, 6000 redline (only z28 and 375 horse BB cars had this) Speedo cable exits firewall on right side of steering column. White over spray in cowl from application of stripes over original green paint. It also is a factory rear spoiler car, and has console gauges which are not specific to any car, just a nice option.
Chime in and I will give you the good bad and ugly of it.
Edit also forgot it still has the E-70 15 tire sticker on the glove box door which no other Camaro that year had 15 inch rims, only Z-28 had these.
As you said, the 68 is the hardest to prove/identify, especially when the original engine is gone. That said, it does sound like your car has a lot of the 68 Z/28 clues.
As far as the dual exhaust, it was standard on the Z/28, but it was also standard on all SS Camaro's, regardless of the engine. Duals could also be had as a option on any 68 V8 engine. Z/28 (and big blocks) got 2 1/4" duals, while other small blocks got 2 " duals.
Another thing to check is the width of the rear spoiler. The 68 spoiler is about 59" wide, while the 69 is 61". Cars with factory installed spoilers, got larger diameter trunk spring torsion bars. The narrow spoiler and larger spring bars, won't prove that it's a Z/28, but they're a good indicator that it was a factory spoiler car.
The Z/28 used a 3 row 21" radiator, while other small blocks used a 2 row 21", though the 3 row also came with AC, and was available as a Heavy Duty option on other small blocks. Big blocks used a 23" radiator.
The master cylinder used on 68 Z/28's was the "046" casting, with a "WT" code stamped on the front. Though this MC wasn't unique to just the Z/28, as it was used with all 68's with front discs.
I'm no expert on Z/28's, but I'm learning more about them all the time. One of my best customers is restoring a 68 Z/28, that I located for him. It's a very interesting car in Butternut Yellow, with it's original numbers matching engine, Rally Sport Package, Black Custom Interior, black vinyl top, tinted glass, under hood light and the very rare correct 68 cowl induction air cleaner (not to be confused with the 69 cowl hood). Strangely, the car doesn't have a console, gauges or spoilers.
OP, there's a website dedicated to the first gen Camaros, called the "Camaro Research Group" (CRG). There's a LOT of information there, and the site is populated by a number of knowledgeable people. They probably could help you
So your customers car has a cowl hood? A lot of people added them later, but they didn't come out until 69.
I have the correct radiator, fan with clutch, intake, carb, heads, valve covers, and even got the correct crankshaft but the original MO block is long gone.
All the correct brake parts are there as well.
The guy had bought all new GM sheetmetal for the cars front end back when it was still available, so RS fenders, lower RS valance, hood (although nothing special because they were flat) inner fender wells, core support, and passenger door which is also factory drilled for the RS trim.
I have never seen a Camaro this dry, and rust free as far as the body, trunk, and floors. The jute under the seats, and carpeting look new, as does the original carpeting. Door panels, Dash pad, seats, even the weather stripping is in remarkable condition. Its actually unfortunate the PO started to restore and removed the front clip as this would be a true survivor car, in fact I do not plan to restore from the firewall back to show how nice the underside of this original car is. I am going to repaint it because it is the wrong color, and all the front metal is Black from being new.
I have heard that there were some documented cars with 4 leafs other than Z28 but literally a hand full if that. The unrestored rear end and springs have never been out of this car.
Old wives tale...all 68-69 Camaro's with 350 engine (10/12 bolt rear) received multi-leaf springs from the factory...normally 307 and 327's got mono-leaf. There were a butt load of cars built with 4 leaf springs based on options ordered...my 69 RS had original 4 leafs. (4s) were unique to the Z!
They did away with mono after 67 because of wheel hop. I don't know about 69, haven't researched it. Whatever it is, it is a cool car that appears to be a real deal Z.
Love the color, in fact the one I am working on is British Green with Black standard interior.
Before the cowl hood was offered in 69, 67 and 68 Z/28's were available with a cowl induction air cleaner. Like the optional headers, the cowl air cleaner was shipped with the car, but uninstalled in a box in the trunk.
The cowl air cleaner was made up of 3 pieces, a closed air cleaner, a curved plastic air duct, and a flexible rubber connector hose. The hose and duct form a 90 degree bend to connect the air cleaner to the firewall. To use the air cleaner, the owner had to cut a hole in the firewall, above the heater box. The air cleaner came with a template and instructions, on how and where to cut the firewall open. When installed, the cowl induction air cleaner draws air in through the cowl vents, through the duct, and into the enclosed air cleaner.
When installed, the cowl air cleaner wasn't as pretty as the 14" open element air cleaner, but it did do a good job of providing cool outside air to the carb.
Received 3,043 Likes
St. Jude Donor '05
Actually did something similar with an Abody
Think its more effective than the 69 CI system
Sounds like a neat find post up some pics.
No, my customers car does not have a cowl hood, it has the standard flat hood. What I said was that the car has "the very rare correct 68 cowl induction air cleaner (not to be confused with the 69 cowl hood)."
That set-up was pioneered with the Z-11 409 Impalas, back in '61. One of my good friends was one of the premier "east coast privateers", back in the 60s, running a '63 split window 'Vette, followed by a '67 Z/28, in SCCA racing. His car had that cold air induction package.
St. Jude Donor '05
Was hoping to do something similar...where the AC used to be. Just dont want a stock looking part have to be fabbed up
Love those first Gen Camaros best bodys ever
Only drawback with running that set-up on a street car, is you'll constantly hear the sucking sound of the carb. It will be transmitted through the heater/defroster vents, since the cowl area is where they draw in outside air, and with that duct, the carb will be drawing from there, too.
So another clue, I dropped the fuel tank, and no build sheet. However it has its born with 3/8 metal fuel line in the sending unit so it is a SB car with the bigger fuel line, and it was not a SS because it would have had a SS gas cap. This car has a RS gas cap, and it appears born with also because of the factory reverse lights in the rear lower valance. The gas caps that were special (SS or RS) also had a cable with a stud that nutted from the inside of the trunk, and attached the cap to the car. This also appears to be factory. The car also still retains it's vacuum headlight switch. So if it was a large fuel line SB car???? Couldn't have been a SS 350 car because of the gas cap and 6000 redline. What else should I be looking for?
