63-67 Power Windows Operation
I took a look at the fuse panel on my 65 and there is one wire from the window harness connected to one of two fuse cavities labeled "Power Windows" located at the bottom of the fuse block. There is also the word "Bat" labeled just to the left of the left cavity where my PW harness wire connects. I don't see any cavities labeled "Acc Fused" but there are two cavities labeled "Acc Lamps" with internal metal blades but nothing connected to them. There are no other wires connecting to any of the other cavities of the fuse panel.
I get 12v with the ignition "off" from both PW cavities and no volts from the "Acc Lamps" cavities in any ingition position (like they are dead).
Does this mean that my fuse block may have been incorrectly connected to the main firewall harness some 20+ years ago when I had all the harnesses replaced? Any easy fix for this?
However, I actually prefer the windows operation just the way they are but I've always been curious about this. It also begs the question about my headlamp motors and power antenna .... they also both work with the ingition off?
Thanks again for your help
