Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Engine Code Help
Old Dec 22, 2005 | 09:11 PM
harrin's Avatar
harrin
Default Engine Code Help
on a 71 corvette the casting numbers is 3963512,the code should be CPH,where do I find this code is it stamped or is it forged? Any help is appreciated
Old Dec 22, 2005 | 11:11 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it is stamped on the pass side of the block were the head is it will stick out about a inch or so, if you look down beside the valve cover you should see it
Old Dec 23, 2005 | 02:02 PM
JohnZ's Avatar
JohnZ
It's in FRONT of the cylinder head.
To Engine Code Help
