Junkyards are about the only source for correct color-coded fuses; the reproductions have the color on the outside, not the inside. While you're grabbing fuses, grab the turn signal flashers too.
Do you mean on the color is on the outside instead of the inside?
Thanks, Dave
I think Lectric Limited sells them, and the color band is on the outside of the glass instead of inside the glass as the originals were made; they get a deduction just like plain glass fuses do.
Plus you will find period correct trim screws, flashers, connectors for various electrical components, etc in your favorite salvage yard. Call ahead and make sure they have the right years of GM cars.
E-mail me @ dterrana@aol.com
I had a block on and it was stopping unkown senders...try it again. Use Corvette forum as a heading or I won't open it!
Dave
Also, a 4-way flasher made by either of these 3 maunfacturors:
Ideal Corproation
Tung-Sol
Signal-Stat
Dave
Dave,
Did you find the flasher you were looking for?
After reading your post I checked my parts. I relocated and modernized my fuse panel and replaced my flashers with electro-mechanical units. This is what I found.
They are from a '74 Vette:
Emergency Flasher - Ideal - metal body - Excelent condition
Signal Flasher - Tung-Sol - Light blue plastic body - Excelent Condition
(1) 25 amp fuse w/white stripe (only one and it was in the wiper slot, go figure)
All worked when removed.
I didn't know you guys got giged for these things, glad I didn't toss them.
If you don't want them someone else might.
I also have the seatbelt interlock module if anyone needs a working one of those.
