Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
70 Vacuum Tank
Old Jan 27, 2006 | 03:59 PM
wolflt1's Avatar
wolflt1
Default 70 Vacuum Tank
Hi everyone,
I need some advice.
I want to restore the vacuum tank on my 70 sb. It holds vacuum so it doesn't have any leaks
The outside is covered with surface rust which probably can be beadblasted or what ever and painted.
What black paint should I use? semi gloss black?
Now, what about the inside? Is there a way to rust proof the inside?
Wolf
Old Jan 27, 2006 | 08:00 PM
toddalin's Avatar
toddalin
Originally Posted by wolflt1
Hi everyone,
I need some advice.
Wolf
If it doesn't work out for you, I have a couple used ones sitting on the shelf that need new homes.
Old Jan 30, 2006 | 08:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Semi-gloss black.
Old Jan 30, 2006 | 12:34 PM
wolflt1's Avatar
wolflt1
thanks for your offer
mine still correctly holds vaccum.
just wanted to spruce it up
To 70 Vacuum Tank
