C1 Wonderbar Buttons
Thanks, John McGraw :smash:
I haven't worked on one in 30+ years, but I used to work on GM AM radios as a kid. If I remember correctly when you pulled the button back in order to set a "preset" it would come out about 1/2 again further than normal. If you look at the underside of the button there should be some sort of spring release mechanism that either pressed into or pried up. This allowed the botton to come off.
This is all very vague and might not be the same on all GM radios. I really didn't work on Chevy Wonderbar radios, my stuff came from GMC/Buick/Pontiac Dealership and an Olds/Caddy dealership.
Chevy radios could have been different.
Sure has been lonely over on the tech board since you all came over here, guess I will need to spend some time over here as well. John :smash:
[Modified by John McGraw, 10:30 PM 8/14/2001]
