Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
CE replacement engines
Old Jul 9, 2006 | 04:29 PM
alaskacorvette's Avatar
alaskacorvette
Default CE replacement engines
Several questions for the experts... During the early '70s, were CE stamped engines available for all replacement needs? I've seen several LS-6 CE engines but no LS-5 or LT-1s. Is there any decoding information for the CE stamped blocks? Thanks, Jim.
Old Jul 10, 2006 | 01:49 PM
JohnZ's Avatar
JohnZ
"CE" engines (only available as short-blocks) were made up to replace all production configurations; the only thing a "CE" pad stamp will tell you is which engine plant made it and when it was assembled - there's no configuration information in a "CE" pad stamp.
Old Jul 10, 2006 | 11:52 PM
alaskacorvette
Default Thanks
John, Appreciate the help! Thanks, Jim.
To CE replacement engines
