Engine Emissions Code
Re: Engine Emissions Code (RMS73)
Roger, two separate vendor catalogs show the 74 L-82 Federal emissions sticker code as "ZF". No discrimination is made for type of transmission. For comparison, the L-48 Federal emissions sticker code is "ZB".
Re: Engine Emissions Code (Chuck Sangerhausen)
Just to add two bits here. The last sticker replacement I got was not the same as the original and was a bit larger than the original. It did however carry the correct code. You may want to look into it before purchasing one, if this is your motive
[Modified by Ron D, 9:30 PM 9/4/2001]
