Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
C3 Right Side Mirror
Old Sep 16, 2006 | 04:15 PM
kaiserbud's Avatar
kaiserbud
Default C3 Right Side Mirror
The right side mirror was an option. To install one, you have to add the mounting plate inside teh door frame. It appears the only way to add this late is to cut into the metal framing on the inside of the door.
Once that is done, is it proper to glue the mounting plate into positon? and what to do about the cut in the door frame?
Old Sep 17, 2006 | 07:34 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
When I added the right side mirror on my 69, it came with two well nuts. All I had to do was locate the position, drill two holes for the well nuts, then mount the base with the supplied bolts. Attach the mirror to the plate just like on the drivers side. Been on there for several years with no problems. All done from the outside of the door. Maybe you have a different type of mirror though. GL
Old Sep 20, 2006 | 09:35 AM
corvetteload's Avatar
corvetteload
It was my understanding that a RH mirror was not an option, at least on 69's. I have one on my 69, really would like it gone, but not much I can do now, same with the aftermarket luggage rack. Later..............B
Old Sep 21, 2006 | 07:29 PM
RMS73's Avatar
RMS73
For the early 70's it was a dealer installed option. When you drill the holes in the door have the window up so the bit can not hit it.
Like said above the well nuts hold the base to the door.
Roger
Old Sep 21, 2006 | 07:38 PM
kaiserbud's Avatar
kaiserbud
Hey Rog .. on my car, there is not possibility of drilling through to the windowm as there is an enclosed channel that encapsulates the area where the mounting plate would rest
To C3 Right Side Mirror
