That code says it's the correct transmission type for the 427, the correct model year ('68), and was made on the 187th day since '68 production started (in February), so it lines up well with your April car. The VIN derivative should be stamped on a raised boss on the forward passenger side of the case or on the driver's side flange where the trans bolts up to the engine.
Thanks. So 1875 is the 187th day. What does the 5 stand for ?
I could not locate any boss with a stamped VIN yet. Have to keep on looking. Unfortunately, a chrome TURBO 400 oil pan is installed. Guess this is not original and might hyde the VIN.
Exactly as I write and wrote is the tag's numbering , as follows:
427
CL 68 1875
So, 427 should be the date and not the engine type ?
So this should be 427 - 365 ( for 1967 ) = the 62nd day of the year 1968, hence around the 03rd of March. Is this correct ?
CL is hydraulic lifter, OK for my L36 car .
68 is modell year 68.
1875 is S/N of the tranny.
427
CL 68 1875
Did SB cars in 68 come with TH350 only ?
Günther
Yes, Gunther. As I understand the system, it's just coincidence that your Julian date is 427.
CL designates a hydraulic lifter BB, either 390 or 400 HP.
The 1875 is the sequential # of the trans for 68.
I have a 69 427/400 with THM 400 trans. My late 69 THM 400 has a sequential number of 2123.
My 1969 Julian date is 550, so 550-365= 185, or the 185th day of 69, which would make it roughly in June of 69.
My 69 was built in late July of 69.
I believe all small blocks in 68-9 had the THM 400, NOT the THM 350. Chuck
looks like the automatic trannys got handled differently than the manuals.
My 68 4sped M21 close ratio actually has a stamped car VIN devirative on it, same as the engine block. Those where apparently stamped at the same time from the same guy with the same stamps together with the engine pad.
The manual tranny is a real numbers matching unit versus the auto tranny only being a correct one.
That's a killer now.
So, there was no system , some have the car's VIN, some not ?
Did you check if the size and fond of the tranny's VIN numbering is the same as on the engine block ?
I know that on a manual tranny, that is a must because been stamped by the same guy at the same time.
I can't see how the car's VIN could be stamped onto the THM400 tag as it is held with one central rivet and actually not sitting flat on the tranny's carcase ?
Do you have a pic of this tag with the VIN derivative ?
Guys, I will try to post a picture later if I can get the angle under the car.
The VIN is stamped on the top side of the panledge of the THM 400 in my 71 454. It is the original transmission to the car and has the data plate and info as shown earlier by John Z.
If my memory serves me correct it is on the drivers side ledge.
