On a midyear (10/1966), which parts of the drivetrain/suspension were unpainted originally? (Halfshaft/flange, driveshaft, callliper brackets (front and rear), Struts, Diff carrier,rear spindle housing/flange, front springs, sway bars, steering box, tie rods?)
For parts left unpainted, are you spraying something like WD-40 on them occasionally to keep the surface rust away with good results?
CAN I USE THE SAME ON UNPAINTED PARTS FOR A 1968 CORVETTE ?
ann
Yes. Any coating on a part that's supposed to be "natural" can be detected in judging, but it's preferable to rust, and only carries a very minor "finish" deduction.
