No Date Stamps
Are these permissible when a car is being judged by NCRS?
My guess is they have been rebuilt or its a replacement part with correct number but no date code.
Your carb's deduction would be five points and you score 29 for originality. Replace the Qjet with a Holley...and your deduction is the full 34 points. We are assuming condition is fine and no deductions are made.
Does that help?
Sure...all is permissible. If the judging guideline spells out a date code and one is not present, than only the absence of the date code is judged...not the entire component. For example using a carb from 1978, it scores originality 34 points and condition 26 points with 5 points assigned to the carb date.
Does that help?
I think the one comment was that the '68 and '69 carbs have the date on the base, so there is no date next to the model number.
Some of these are a bit rough in the throttle plate area and so they can be hard to see, while others are clear. But add some dirt, leakage, and a few years, and you may not see it.
Can you put up a picture of the carb in question? Is it an ebay item? Do you know the year or can you put up the model number?
Some 1969 carbs have a date on the main body, like this.
And some don't, like this one.
Some also use the full number, like 7029203 where others use 29203 without the 70 at the beginning.
It could be with whether it is a Carter built or Rochester built, but I don't know.
If you look at this one, the red spot on the base is about where the date should be. As you can see, it is a bit rough and doesn't appear well, so it is possible to have a date there and simply not see it.
Hey, it is Post 427. Not relevant to the thread, just a thing I have for numbers.
If you are trying to justify a dateless carb for your 69 as an original, your guess is as good as anyone elses. Trust me, you can go crazy trying to make sense of some of these things.
For me ,I would look for one with a date, and take the guesswork out. As I've said, that 7029207 has date codes well into the 90's. Here's a late 68 version.Around Oct 12, well within the acceptable 6 month window for 69. Or is it 78,88,or 98? See what I mean
