Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Q-JET
Old Oct 19, 2001 | 02:13 PM
JK80's Avatar
JK80
Default Q-JET
I could use a little help. I have a 1980 stock L-48 350 with a rochester Q-Jet #17080204. Between the carb and manifold is a heat insulator it is about a 1/2 thick. What I need to know is do you still use a carb gasket here or does the heat insulator also act as a gasket? I'm hoping someone knows the answer.
-John-
Old Oct 19, 2001 | 06:14 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Default Re: Q-JET (JK80)
My experience with mid-sixties Chevys with the brown fiber insulator was that the insulator served as the gasket. If the insulator is soft enough to be marked with a fingernail, it will deform to the surfaces on the carburetor body and the manifold, and will seal better than it would with gaskets.
