1969 corvette block casting 3963512
Block casting date is on side near front of starter, if you need pics I can comply...........
To post a pic, you need an FTP site with your internet provider, or a hosting site on the net, they are abundant. When posting click the "insert image" icon and paste in the location of the pic and it will show up.............B
Sounds like a restamp, but there could be a valid explanation for it. Do you have any documentation with the car?
A "512" casting with February 1969 casting date is pretty much standard fare for 427s... Nothing to be alarmed about there.
Yes, it is odd and yes, I have seen stamps like this before on a factory stamped pad. First off, all big block Corvettes were stamped in the assembly/VIN derivative sequence that you mention... Assembly stamp on the left, VIN derivative on the right... Nothing out of line there. The really odd item (that you also noted) is that the last character of the broadcast code (in the assembly stamp) appears to be stamped separately which was not typical of most factory stamps and normally would be a hint that perhaps something isn't right.
However...
The one thing that got my attention (and makes me think that it could be a factory stamped pad) is the application. The "LX" broadcast code is for an L-71/M-40 application which is a pretty rare combination... A 427/435 backed by a heavy duty THM 400 automatic. This is also an early assembly stamp for one of these engines as the L-71/M-40 wasn't offered until about the middle of the 1969 modely year. It is possible that the last character was hand stamped due to the reasons mentioned above. As I mentioned, it is conjecture without inspecting the pad, but it is possible.
Is this just an engine that you are looking at, or is this engine installed in a car? If it is still in the Corvette that it was installed in, there are some other items worth looking at that were specific to solid lifter big block/automatic transmission Corvettes. Any additional details would be appreciated.
Regards,
What else should I look for? I will try post or send a picture of the pad to you. I have an all orginal 1966 roadster which I have had for about 20years and famliar with the pad and factory stampings. Also I have looked at a taken pictures of other 1969 427s. The fonts of the characters spacing, alingment and stamp depth look like others I have seen except for the displace X. Which is odd...If not for the X I would not question the stamping. Also if this was restamped it does not make sense that someone stamp every character with symmetry only to slighty displace the last charcter X. Anyway I will try to send the photo. Thanks Again.
Regards,
Stan Falenski
