Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
need help with anL88 decoding....
Old Jun 22, 2007 | 02:59 AM
rgearhead's Avatar
rgearhead
7th Gear
Default need help with anL88 decoding....
its as told a 69 casting casting # 3963512 and the deck #s are ce172383here is alink to some pics if it helps,,,,thanks bob.b
Old Jun 22, 2007 | 12:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
3963512 is good. The CE indicates this is a replacement block, possibly bought over the counter at GM, or replaced under warranty by a Chevrolet dealer.
Your link doesn't work for me.
Old Jun 22, 2007 | 05:08 PM
Mike Ward's Avatar
Mike Ward
The 512 block was used in all sorts of BB engines, not just an L88. The CE number can not be decoded into any particular engine type or configuration.
Sorry.
Old Sep 6, 2007 | 11:03 PM
Ironcross's Avatar
Ironcross
I believe all warranty replacement engines regardless of size as dealer installed were stamped as "CE" after a certain date, possibly in 1968. However as a over the counter short block or long block they too had "CE" sometime in 1968 including the 512`s.
Not sure, hell I don't know. if pickups enjoyed the same designations
PS, don't bet your girl friend or whatever on my reply.
To need help with anL88 decoding....
