Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Calling Easy Mike
Old Nov 2, 2001 | 02:33 PM
R1234's Avatar
R1234
Default Calling Easy Mike
Hi Mike,
Being that you are a fellow 68 owner, I would like to ask you a question concerning the the hook up of my wiper motor. I'm using a rebuilt wiper motor, along with a replacement washer pump. The engine wiring harness is also new from M&H. The engine harness has two #18 pigtail wires coming out of the wiring harness, one is yellow and one is dark blue. They have male barrel connectors on each end. On the engine compartment side, the aim shows them hanging in mid air. Following the wires back through the bulk head connection, the yellow wires winds up at one side of the wiper switch relay. The dark blue wire winds up at the wiper switch. Are these the connections to the washer pump?
Thanks again
Old Nov 2, 2001 | 03:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Default Re: Calling Easy Mike (68rdstr)
69rdstr -- I'll check my AIM this evening when I get home and get back with you.
Old Nov 2, 2001 | 07:00 PM
Easy Mike's Avatar
Easy Mike
68rdstr -- the 18 gauge yellow and blue have me stumped, too. In the wiring diagram in my AIM, they literally do not connect to anything. They could be for the washer pump.
Old Nov 2, 2001 | 08:00 PM
R1234's Avatar
R1234
Default Re: Calling Easy Mike (Easy Mike)
Mike,
I have all the other wires to the wiper motor connections accounted for, that leaves the washer pump that has two black wires coming from it. I checked the service manual and could not find anything related to washer pump hook up.
To Calling Easy Mike
