Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
quick ? on a 68.
Old Sep 14, 2007 | 09:36 PM
RPOL36's Avatar
RPOL36
Default quick ? on a 68.
did they use any kind of washer on the 8 exhaust manifold bolts on a 68?
I thought about putting lock washers but this is a NCRS restoration so I'm being picky about even little stuff like this..
thanks
Old Sep 15, 2007 | 09:20 PM
JohnZ's Avatar
JohnZ
Small-blocks and big-blocks used special thick flat washers under the end pairs of bolts, with french locks between the bolt head and the washer. No washers or french locks under the center pairs of bolts. That's how it is for 67's, pretty sure '68 is the same. You'll find the '68 setup described in the "Mechanical" section of your '68-'69 Judging Guide.
Edit: 1968 may be different - I recall Joe Lucia posting on the NCRS Tech Board that BB's used special self-locking exhaust manifold bolts starting in 1968, with no washers, and AMK Products (www.amkproducts.com) stocks them.
Old Oct 19, 2008 | 10:37 PM
RPOL36's Avatar
RPOL36
i am not a ncrs member could you find out the details from joe for me please?
i talked to him once seems like he told me the kit i ordered from paragon is right for 6 out of the 8 bolts per side but that the end bolts on each end are locking and the 6 in the middle are not and are correct.
and where to get these locking ones that are correct thanks man
seems liek i somehow got into the ncrs forums and asked and he answered but now i can't seem to be able to post in there without paying....can't even make a GUEST account which i think i was able to a year or so ago.
Old Oct 20, 2008 | 09:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by RPOL36
...i am not a ncrs member...
So why not join? You're going to a lot of time and expense getting your car correct. NCRS membership could help with that and get you on to their forum.
Old Oct 20, 2008 | 05:00 PM
JohnZ's Avatar
JohnZ
If you're doing a restoration, the $35.00 to join the NCRS is the best $35.00 you'll ever spend, and joining your local chapter will get you even more - that's where all the folks are who can help you with your project.
Old Oct 21, 2008 | 09:07 AM
Easy Mike's Avatar
Easy Mike
Amen. It's money well spent regardless of whether you're doing a restoration.
To quick ? on a 68.
