Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Window Tray
Old Nov 29, 2001 | 02:06 PM
MikeT's Avatar
MikeT
Default Window Tray
Guys...need your help! What year did the removable window tray go from being a relatively flat piece to a "form fit" tray??? I've seen both and want to be sure of what I'm getting!
Thanks,
Mike
Old Nov 29, 2001 | 02:37 PM
Marks69BB's Avatar
Marks69BB
Default Re: Window Tray (MikeT)
Mine in my 69 is formed and contoured to allow the window to be clamped into it. I've never seen another 'version'.
Old Nov 29, 2001 | 03:48 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Mike, there are several different versions of the tray in the early years, and it takes a person experienced in all the year classes to sort them out. For example, I believe 68 had a one-year only tray with spring-loaded hinges that held the tray in the up position. By 70, the hinges are just simple sheet metal hinges with no springs.
Your use of the term "form-fit" is a little confusing. The early trays themselves are made of a molded fiber board type material that was black flocked up through 71. They have latches and clips that retain the rear window in position. In 72, they were "molded" of black plastic material with deep substantial ribbing for strength. In 73, the removeable rear window and storage tray were discontinued.
[Modified by Chuck Sangerhausen, 12:53 PM 11/29/2001]
Old Nov 30, 2001 | 04:20 PM
MikeT's Avatar
MikeT
Default Re: Window Tray (Chuck Sangerhausen)
Thanks Chuck! I guess "molded" was a better description. Sounds like the 71&72 are the best ones!
Thanks,
Mike
To Window Tray
