Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Where do I find Anodize?
Old Feb 19, 2008 | 07:58 PM
Merlinhaggard's Avatar
Merlinhaggard
Default Where do I find Anodize?
Ive heard of guys Anodizing stuff in their oven..
Also plating stuff at home..???
Old Feb 20, 2008 | 08:16 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
For DIY plating, you might want to try these guys...
http://www.caswellplating.com/kits/index.html
They offer some excellent plating kits for the hobbyist. Pretty good reputation in the business as well.
Regards,
Old Feb 21, 2008 | 04:50 PM
DooDa's Avatar
DooDa
5th Gear
I agree W/ Rowdy Rat, I've used several of thier products with good results . Good luck DooDa
Old Feb 21, 2008 | 06:30 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Anodizing is a chemical process for aluminum. It's basically forming a layer of aluminum oxide on the surface of the part. Aluminum oxide is harder than most aluminum alloys, so this increases the life of parts that are subject to wear or errosion. It can also add color to the parts.
Are you thinking of powder coating? That's a powder that is applied to a metal then baked on in an oven. It's an alternative to painting, has a tougher surface. It's available in a lot of colors.
You can buy a kit for powder coating and use a household oven for the baking. Don't use your wifes good one though.
Old Feb 21, 2008 | 07:25 PM
mod81's Avatar
mod81
Also, on a cheaper note if you just need a quick touch up job, Mid America sells factory matched anodized spray cans. Just an FYI if that's an option. I'll probably go that route for my rear window trim.
Old Feb 21, 2008 | 09:47 PM
Bowerss2's Avatar
Bowerss2
I can shed some light on this, my family runs an Anodizing factory. Like said above, its a chemical process, your thinking of powder coating at home. There is very little on a vette that can be Anodized, as you cant Anodize cast aluminum because it is porous it will pit. www.bowers-mfg.com this is our place, cheers,
Steve
Old Feb 22, 2008 | 11:55 AM
68/70Vette's Avatar
68/70Vette
Originally Posted by Bowerss2
I There is very little on a vette that can be Anodized, as you cant Anodize cast aluminum because it is porous it will pit. www.bowers-mfg.com this is our place, cheers,
Steve
On the 1970,71, and 72 C3's the LH and RH front grills are chrome plated aluminum. Also the 69 factory side pipe exhaust covers are chrome plated aluminum. My understanding is that before aluminum can be chrome plated, it needs a conductive anodiz coating before the traditional chrome plating processing can take place. Aren't these aluminum pieces cast aluminum? Also, since I have some of these parts that I would like to be rechromed, can you provide some words about the technics of anodizing aluminum in preparation for chrome plating?
Old Feb 22, 2008 | 03:32 PM
comp's Avatar
comp
Steve
didn't know about cast
Old Feb 22, 2008 | 10:17 PM
Bowerss2's Avatar
Bowerss2
The process for chroming aluminum is identical to the process used for steel except for the use of special pre-plating solutions to allow the copper, nickel, chrome plating to adhere to the aluminum surface. but we dont do any chroming, not enough volume anymore. Anodized coatings are non conductive, which is why we need to clean the anodizing off the threads for the end caps of maglites, we do their black, sliver, gunmetal, we also do work for steelcase, sub zero, wolf, viking, and u-line. There are some good at home kits from Caswell, but it would probably be cheaper to find a chromer to do the re chroming for you, good luck,
Steve
To Where do I find Anodize?
