Whats it worth?
This car is truly worthy of a NCRS resto
62 Vette 327/300/4 spd./2 tops
Honduras maroon/black needs paint and chrome
3 owners
No hit body/never rusted frame.
All #'s match engine,trans,rear, even the ring and pinion.
This car has never been screwed with and retains all of the following ORIGINAL not repro parts.They actually came with the car when new!
Wonderbar, shifter,washer setup still has the original hoses and aluminum tie straps,original rebuilt waterpump,original rebuilt generator with original voltage regulator.original horns and horn relay.,exh manifolds,rear springs,master cylinder,all original chrome,hubcaps,intake manifold,wiper motor,ignition shielding,radiator,expansion tank,balancer pulleys etc.
The only thing it is missing is the 3269s carb(has a 3721)
The frame was blasted and imron primed then painted chassis black. The entire running gear is either new or rebuilt,as is the brake system,and suspension It has a aluminized off-road exhaust with correct hangers.It also has a new Al Knoch installed black convertible top.
I have driven this car over 20k miles in the last few years and would not hesitate driving it across country tomorrow.
It will do 80 mph all day long in 90 degree heat and gets 20-22 mpg on the highway. It is a well sorted out driver that needs paint and chrome.
Sorry so long,but what do you think its worth?
:cheers:
Bob
Thank You
Andy Wilcox :smash:
Nevermind I just found it in c1/c2 page.
[Modified by INMYBLOOD, 9:27 AM 12/13/2001]
