Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1969 carpet question
Old Jul 23, 2008 | 12:23 PM
marky mark's Avatar
marky mark
Default 1969 carpet question
I am re-doing thei nterior in my 1969 convertible and wanting to know if there was any difference in the carpets kits regarding the high beam foot pad area.
Did the original interiors have the high beam metal cap exposed on some early models. Or was it always covered by the carpet/pad?
Any help appreciated as there seems to be more than one version of carpet kits out there regarding this area.
Thanks, Mark
Old Jul 24, 2008 | 09:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory serves, the dimmer switch was covered by the carpet, possibly (depending on year) with a vinyl pad over it. The folks at Al Knoch would know. http://www.alknochinteriors.com/catalog.htm
Old Jul 24, 2008 | 11:58 AM
marky mark's Avatar
marky mark
Thanks Mike. I will check them out.
Mark
Old Aug 4, 2008 | 07:50 AM
corvetteload's Avatar
corvetteload
Early didn't have the pad, carpet covered the switch. Later had the pad, check your assembly manual..............B
Old Aug 4, 2008 | 10:24 AM
Easy Mike's Avatar
Easy Mike
Thought so. No pad on the '68s either.
Old Aug 6, 2008 | 03:52 PM
tls630's Avatar
tls630
I put ACC carpet in the last one I did and it worked much better and fit a whole lot better than Al Knoch's..Besides if you have a problem the only one that will handle it is Al. Try getting ahold of him this time of year. Good luck !
Old Aug 26, 2008 | 07:13 PM
DZRick's Avatar
DZRick
Do you have the pedal that goes under the carpet?
To 1969 carpet question
