1968 radiator?
bigredbrad
bigredbrad
Regarding sidebrackets, the ones in your first picture look very original to me. The original Harrison cores had the steel sidebracket with a small square and small rectangle hold punched in each of the end. If the core is already ordered and the side brackets are different, and you are going for 100% originality, ask the shop if they can switch your old ones off and put them on the new one. This is definitely NOT a job for a rookie radiatorman, but if they have an old guy there, I bet he can do it.
Post some pics when done!
bigredbrad
p.s. to see a link to our website click here:
http://www.deansradiator.com/RadiatorRestoration.html
If you click on the first picture of the 427 radiator, you can see the incorrect, but current style inverted side brackets. Click on the picture to see it at full size and you can see the side bracket is shaped like a "U". This is technically incorrect, but this particular customer wanted the proper cooling of a new copper radiator without spending the extra money to put on the correct original harrison sidebrackets on. As you scroll down that page, you will see a sandblasted tank. Once all the dents are out, this tank will hold paint real nice and look great since all the old crud is sandblasted off.
Goodluck!
brad
