Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1968 radio?
Old Jan 21, 2009 | 08:24 PM
Ronaldo's Avatar
Ronaldo
Default 1968 radio?
Can somebody help me identify if this is a 1968 radio?
Model number: 7302721
Other number: 7303275
Old Jan 22, 2009 | 07:47 AM
gbvette62's Avatar
gbvette62
I'm in Kissimmee for the NCRS show, so I don't have any of my parts books, etc.. at hand. I can tell you that the 68-76 radios are all basically the same. The 68-71 face should have numbers with a green tint, the 72-76 numbers are white. I can't tell from the photos which face is on that radio. 68-76 radios have a separate amp, which isn't pictured. The amps used in 68 are unique to 68, where as the 69-76 amps are all the same (though stereo and mono each use a different amp). I believe the plug for the amp is the same on all radios.
Old Jan 22, 2009 | 08:10 AM
Ronaldo's Avatar
Ronaldo
Thanks for the information. Its because my 68 is missing the original radio but the seperat mono amp is still in the car. I bought the radio on the pictures which (according to the seller) came from a 1968 corvette but I have not been able to find a place to verify the numbers...
Old Jan 22, 2009 | 10:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You might try contacting GM-Delco (or it's new name equivalent) in Kokomo, Indiana. They can identify the specific year by the codes on the tag. They helped me years back.
What you have looks like '68, but the 68-76 units all resemble each other.
Old Jan 22, 2009 | 12:32 PM
GoGreen's Avatar
GoGreen
3rd Gear
Default Radio expert recommendation
Ronaldo:
I bought a 71 with an orig Delco radio & components in a box in unknown condition.
I sent them all to Jerry Rudbeck in South Carolina.
He did a great job of bringing the whole system back and explained exactly how it all went together. Also added an iPod input into the back of my U79 stereo that sounds great.
I recommend you email these pics to Jerry. He'll definitely help you out.
His email is: jerry@electrodesign.us
Good Luck, Tom
Old Mar 9, 2009 | 09:38 AM
AvRog's Avatar
AvRog
That is the U69 option that I too have in my 69 and the numbers are correct. Let me know if you have any wiring info as all my connections have been cut.
Good luck, Roger.
Old Mar 9, 2009 | 10:12 AM
Ronaldo's Avatar
Ronaldo
Good luck, Roger.
Thanks, can't help you with the wiring as all of mine also was cut. Damn you Bubba
Old Mar 11, 2009 | 10:13 PM
Jerry - Radio Guy's Avatar
Jerry - Radio Guy
Ronaldo and AvRog, the 7302721 model number comes up as a 68 and was also listed as the chassis type for the 69 and 71 (that's from the Sams Photofact manuals and is supported by the little digging I did into the original Delco radio service manuals). Did you get the 7303275 number off the chrome escutcheon on the radios front? Too tired tonight to dig through all those parts manuals but it does not come up as a radio model type number. Wiring: there should be three plugs to work with. The one on the case side is -from front to back- radio power, ground and dimmer control. The connector with 3 pins -wires are usually colored blue, yellow, green- goes to the convector (the firewall mounted heatsink and big round transistor). If that's been cut you'd have to know more about radios to re-wire it. Plus, that pigtail is wired into the radio and is a devil to find aftermarket. (Supposedly I have two new ones coming in a shipment - I hope.) The third plug will usually have two green and one black wire (there were variations). The greens go to left and right speakers and the black is the common return (ground) from the second speaker connection on the left and right speakers. Hope that helps a bit... the 68-72's are a confusing mess as far as the numbers but usually consistent as far as circuitry. :-) Jerry www.electrodesign.us
Old Mar 12, 2009 | 06:57 AM
AvRog's Avatar
AvRog
Thanks Jerry, what can I expect to pay for the convector?
Roger.
Old Mar 12, 2009 | 07:27 AM
Jerry - Radio Guy
Well Roger, one went for $107 + shipping this week on eBay. Now, what should you expect to pay? Somewhere between $25-$40 US plus shipping WITH the connector and wiring attached. Don't plan on finding the harness easily in the aftermarket if it's missing from the heatsink. The entire unit comes up regularly on eBay - there are plenty of them out there.
Old Mar 12, 2009 | 03:27 PM
Ronaldo's Avatar
Ronaldo
Originally Posted by Jerry - Radio Guy
Ronaldo and AvRog, the 7302721 model number comes up as a 68 and was also listed as the chassis type for the 69 and 71...
Thanks Jerry. Yes the 7303275 number is from the chrome front.
Old Mar 13, 2009 | 09:36 AM
AvRog's Avatar
AvRog
Thanks Jerry
Roger.
Old Dec 26, 2009 | 09:34 PM
bkvette3's Avatar
bkvette3
Excellent Delco radio info on www.wonderbarman.com Should be able to find your answer there. Click on Delco models and date codes.
To 1968 radio?
