Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Torque Specification question
Old Feb 10, 2009 | 04:14 PM
tshirttom's Avatar
tshirttom
Default Torque Specification question
The torque specifications in the owners manual..Are they meant for dry or lightly oiled fasteners? I usually hate putting a dry fastener on and also always use never-seize or some lube. I am sure this affects the torque valves, but in a quantifiable manner? . Any mechanic or engineer want to weigh in on this please?
Old Feb 10, 2009 | 04:26 PM
GDaina's Avatar
GDaina
I believe those are dry specs
Old Mar 5, 2009 | 02:43 PM
tshirttom's Avatar
tshirttom
Default Torque Specs
Will using a long extension on the torque wrench affect the result at all?
Old Mar 5, 2009 | 07:14 PM
JohnZ's Avatar
JohnZ
Nope - only if you use a crowfoot wrench/socket on the end whose center is offset from the axis of the extension.
To Torque Specification question
