Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Brake Line Mounting
Old Jan 25, 2002 | 01:22 PM
GregP's Avatar
GregP
Default Brake Line Mounting (addition-what year did they change ?)
Egad, another resto question. This is getting habitforming :)
Anyway, my AIM says the brake line to the rear is secured to the top of the frame rail. Anyone have a good photo of where and how? Are the clips bolted or welded? Looks like that's the best routing I can find, so might actually copy the factory approach there.
-Greg
[Modified by GregP, 12:39 PM 1/26/2002]
Old Jan 25, 2002 | 02:19 PM
Andy B's Avatar
Andy B
Default Re: Brake Line Mounting (GregP)
Greg,
This photo is not great but it does show the basic layout of the rear brake line. It is held on with little green clips that snap into holes in the frame rail. I bought a brake line clip set from zip to replace some of the deteriorated ones, it was complete but they are not the color or quality of the originals.
Andy B
Old Jan 25, 2002 | 03:05 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Egad, another resto question. This is getting habitforming.
Yep, I am sure it's happened now; the ****-retentive restoration alien has laid its evil eggs in your soul and they are INCUBATING!!!! Two years from now when you're still trying to get "Project No Points" ready for Top Flight, you'll be thinking..."What was I thinking, picking a former race car to restore!"
:D :lol: :jester :lol: :D
Old Jan 25, 2002 | 04:17 PM
GregP's Avatar
GregP
Default Re: Brake Line Mounting (Andy B)
Andy - Thanks. I'll have to see if the clip hoes are still detectable in my frame.
Chuck - Ok, put my car down on your schedule for flight judging in 2003. Just be sure you bring a big box of pencils to list all the areas I need to "correct" :)
-Greg
Old Jan 25, 2002 | 07:46 PM
67HEAVEN's Avatar
67HEAVEN
I dunno Greg. Those front wheelwells don't look exactly stock.
Hmmmmmmmm!
:D
Old Jan 26, 2002 | 01:39 PM
GregP's Avatar
GregP
Default What year did they change the brake line routing?
Ok, so what year(s) did the change the brake line routing ? I was looking at some '67 roadster resto photos and his brake lines run along the bottom of the fram rail on the inside. My frame doesn't have any holes that I can find along top to match the pictures Andy B posted, but dows have holes in the locations where the '67 roadster's lines were.
-Greg
Old Jan 26, 2002 | 01:55 PM
JmpnJckFlsh
Default Re: What year did they change the brake line routing? (GregP)
Greg, the later cars (68? up maybe) have the brake line clamped high on the inside of the frame rail with loop-type clamps with self-tapping metal screws. If this were the case on your 67, I would expect to find a half dozen or so round, previously threaded screw holes along the driver side frame rail (frame metal may be pulled out ever so slightly around the hole).
It seems that some of the changes that were made on the later cars were sometimes first implemented on the 67. This may be because it was the mid-year that wasn't supposed to have happened, but resulted when the 68 design wasn't going to make the deadline.
P. S. I thought your car was a 67; check the frame VIN stamps and see what year the frame belonged to.
[Modified by Chuck Sangerhausen, 10:59 AM 1/26/2002]
Old Jan 30, 2002 | 11:48 AM
Juliet's Avatar
Juliet
Default Re: What year did they change the brake line routing? (Chuck Sangerhausen)
Would be nice Chuck - the rear kickups are long gone and replaced with tube frame chassis. I don't think he's had the body up enough to check the area by the rocker panel covers. I'm just waiting for him to set the precedent of lifting the body off the frame in our garage. :jester
Old Jan 30, 2002 | 01:26 PM
JmpnJckFlsh
Default Re: What year did they change the brake line routing? (Juliet)
Whoa, what's this?...Restorist Juliet waiting for tube frame hubby, Greg, to blaze restoration trail??? WAZZUP? Having second thoughts about the frame-on restoration? :D :D
Old Jan 30, 2002 | 06:12 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Greg, another thing to think about is by the time you get that car done, NCRS will probably have a "PRO Flight Award" anyways :lol: :lol: :lol:
To Brake Line Mounting
