Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Anyone done business with Precision Engineering....
Old Feb 12, 2002 | 10:33 AM
topless68's Avatar
topless68
Default Anyone done business with Precision Engineering....
They advertise in The Driveline brake kits and T/A's and etc. They have a brake kit to rebuild your own calipers, including pistons, seals, o-rings etc for $149. Not bad huh?
I think I am going to try them out and re-build my own. :cheers:
Old Feb 12, 2002 | 10:36 AM
mayberg's Avatar
mayberg
Default Re: Anyone done business with Precision Engineering.... (topless68)
They did my brakes. I don't have them back on the car yet, but hope to be on the road later this spring after the front suspension rebuild.
They seemed to be the most reasonable, and would rebuild MY calipers instead of switching them out for another rebuilt set.
GM
Old Feb 12, 2002 | 12:33 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
If your calipers have never been bored out and sleeved with stainless steel, you may want to consider having them rebuilt professionally the first time (mark'em and tell'em you want'em back).
After 30-35 years, all those original calipers are very likely to have corrosion damage to the bores, leading to damaged seals, and leaks. If you're not leaking, perhaps it's worth a try, but you may be setting yourself up for short service life and possible waste of $149.
Old Feb 12, 2002 | 12:42 PM
allenz's Avatar
allenz
Default Re: Anyone done business with Precision Engineering.... (Chuck Sangerhausen)
During the chassis restoration, I bought 4 rebuilt original calipers then sent back as cores the four that were on the car. I think the cost for the new ones ended up in the $80/ range....
I really didn't want to mess around with such an essential function.
My 2 cents.
Allen
Old Feb 12, 2002 | 12:46 PM
topless68's Avatar
topless68
Mornin' Chuck... :seeya
All of the calipers are replacements and have SS sleeves. I thought the O-ring type piston was better than the OE with the groove in it, that's why I was considering the change. Plus, while I have them down for blasting and changing the bleeders, I'm gonna go ahead and do the seals...
Out of four calipers I have two broken bleeder screws...not bad huh? My next posted question was going to be: Can you drill and helicoil the bleeder screws or am I wasting my time b/c they will leak? Can I drill and attempt to tap?
Suggestions? :cheers:
Old Feb 12, 2002 | 06:25 PM
JmpnJckFlsh
Drill and tap? I don't believe I would try to drill them out myself. I might try a few things to loosen them up (soaking in penetrating oil, mild heat maybe), and then try to use an extractor on them. If that failed, I believe I would take them to a machine shop, and let the pros remove the broken ends.
Jes' call me chikken. You could seriously damage your calipers by using sharp objects on them. :D
To Anyone done business with Precision Engineering....
