Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
69 power windows
Old Feb 17, 2002 | 04:12 PM
micks69's Avatar
micks69
Default 69 power windows
P/w has 3 wires on each side (driver and passenger) connecting to the motor. The pass side has a brown wire attached to the motor frame. My driver side is just lapping around. I looked in the AIM and shows it going to the body of the motor. But I cant tell where. Any input would be greatly appreciated.
Old Feb 17, 2002 | 06:44 PM
Corvettes White's Avatar
Corvettes White
Default Re: 69 power windows (micks69)
Mick,
Damn, talk about timing. Just came in from the garage from putting the pig tails in on the PW motors. ’69 no less. There is a tab screwed to the body of the motor. That is for the ground wire. Should be black. Other wires are “Up” and “Down” and go to the pig tail shown in [View B] on page J303 of the aim.
George
:chevy
Old Feb 17, 2002 | 08:28 PM
micks69's Avatar
micks69
Default Re: 69 power windows (999)
999,
on drivers side where is the tab towards front or rear of motor? I dont see a tab to connect the ground. BTW windows work fine without it on????
micks69's Avatar
micks69
999,
micks69's Avatar
micks69
999,
Old Feb 17, 2002 | 10:28 PM
Corvettes White
Just came in for dinner. Door are still open will check.
George
Old Feb 17, 2002 | 11:08 PM
Corvettes White
Took a look, can’t see where it clipped on. You can just ground it to the motor if you want, short of pulling the motor out. The motor will ground through the door frame to the body which is why ir works but a positive ground is better..
George
Old Feb 18, 2002 | 01:15 AM
micks69's Avatar
micks69
Thanks george. I'm wondering if both sides drivers and pass need to be grounded :confused: because the pass is right to the motror just like you said. Thanks for looking.
Mick
Old Feb 18, 2002 | 03:57 AM
Corvettes White
Mick,
Both sides should be grounded. Seeing you have your doors apart, as do I, it is just as good a time as any to fix any "loose ends."
:seeya
George
To 69 power windows
