Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
How can I id my engine?
Old Mar 28, 2002 | 09:30 PM
kaz1961's Avatar
kaz1961
Default How can I id my engine?
Hi guys. I recently bought a 1987 El Camino which has a Corvette engine in it. Could someone tell me how to identify what engine it is? Thanks for the help.
Old Mar 28, 2002 | 09:53 PM
Mac's Avatar
Mac
Default Re: How can I id my engine? (kaz1961)
Welcome aboard, kaz1961.
If the engine is an original Corvette engine (ie: the seller wasn't blowing smoke up yer hoop) there should be an engine block 'stamp pad' which will be bare metal and have a series of numbers stamped on it. From these numbers, you can determine what year & model your engine is. There are a number of other methods as well, which I'm sure others on this Forum can relate to you, but this is one of the easiest. If you get the numbers and post them, I'm sure someone will check the references on your behalf and tell you what you have.
Old Mar 28, 2002 | 10:02 PM
DaBo's Avatar
DaBo
Look at this area of your engine on the front of the passenger side.
Post the numbers that are stamped into this pad and we will decipher for you.
Old Mar 28, 2002 | 11:54 PM
67HEAVEN's Avatar
67HEAVEN
kaz1961,
Welcome aboard. The guys are correct. Post the numbers.
To How can I id my engine?
