Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Front spindle gasket - what does this thing do?
Old Apr 12, 2002 | 04:45 PM
mayberg's Avatar
mayberg
Default Front spindle gasket - what does this thing do?
Friends,
I've got the driver's side front suspension disassembled, and the spindle gasket - a felt-like ring on the face of the spindle, behind where the hub would mount - is off for cleaning the spindle.
So, uh, what does this thing do? If it's not too expensive, should I just replace it? What adhere's it to the spindle?
Inquiring minds want to know.
Old Apr 12, 2002 | 05:03 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Front spindle gasket - what does this thing do? (mayberg)
I believe it keeps the wheel bearing grease from leaking out the back. Chuck
Old Apr 12, 2002 | 09:26 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Guy, it's described in the parts book as "Part No. 3953412, 69-72, Felt Seal Assembly, front inner wheel bearing".
There is lip seal that keeps the bearing grease from leaking all over, but any lip seal is not 100 percent effective. My theory is that this felt seal keeps dust, dirt, mud, whatever from sticking to the back of the hub assembly where there is normally a barely detectable film of grease. If grunge accumulates on top of the lip seal, the seal wear rate would increase, and eventually there could be contamination of the grease in the inner bearing. JMO.
I would definitely replace them. I think there is also be a paper gasket between the spindle and the brake backing plate, but the function and need for that gasket is less clear.
[Modified by Chuck Sangerhausen, 6:26 PM 4/12/2002]
Old Apr 14, 2002 | 01:11 PM
stingray72's Avatar
stingray72
Default Re: Front spindle gasket - what does this thing do? (Patrick Tighe)
"The front spindle gaskets are cheap, I just replaced them. I got mine from ZIP, and they look like regular gasket material".
You musta got a Zip special, those parts are supposed to be made from Cork. What are Zip's made from? Are they cork?
George
To Front spindle gasket - what does this thing do?
