Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
tempiture sending unit replacement
Old Apr 14, 2002 | 01:23 PM
Ih2lose's Avatar
Ih2lose
Default tempiture sending unit replacement
Guys who has the closest tempiture sending unit.Mine is way off from my readings with a digital lazer thermometor.1966 b/b car
Old Apr 14, 2002 | 02:44 PM
JohnZ's Avatar
JohnZ
Default Re: tempiture sending unit replacement (Ih2lose)
The best one is an old one from AC (hard to find, expen$ive - try Mary Jo Rohner, http://www.vettegal.com); next best is a Wells #TU-5 from AutoZone. In either case, your gauge reading is likely to be hotter than the temp really is. Short of adding resistors to the sender circuit, your best bet is to correlate your I.R. gun reading with what the gauge is telling you so you know how the two relate.
Old Apr 15, 2002 | 08:19 PM
Ih2lose's Avatar
Ih2lose
Default Re: tempiture sending unit replacement (JohnZ)
John thank you for the recomendation I ordered it should have it on thursday cost 39.95 plus hipping and handling I will see how it works
To tempiture sending unit replacement
