Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
68 lost ignition key
Old Apr 27, 2011 | 05:55 PM
sparko1969's Avatar
sparko1969
Default 68 lost ignition key
I recently acquired a 68 vette, with no ignition key or door key. Is the door key the same as the ignition key? Will the door tumbler have a code so I can have the ignition key made?
Old Apr 30, 2011 | 03:20 PM
JohnZ's Avatar
JohnZ
Unless the locks have been changed, the ignition and door lock cylinders originally used the same key; if you remove a door lock, the key code will be stamped on the cylinder, and a locksmith can cut you a key to match it.
