Help with crayon marks
You will also find this same job number on the front face of the luggage stop bulkhead right behind the seats, the left lower fire wall behind the splash shield, on the rear surface of the passenger compartment bulkhead (drop your tank to see it), and maybe one other place that I can't remember. You may also find the last two digits of this job number under the blackout in the front of the right wheel well. The job number told the assembly line workers to install those options which had been ordered on this particular car.
You will find crayon "reminder" marks all other the car in areas where the assembly line workers would need to install some component associated with the option. For example, the A/C in the rear floor area probably told the workmen to delete the astro ventilation valves and install the block off plates, and to install the AC wiring harness, ducts, vacuum controls, etc. Sometimes in the area where you found the "A/C" and "461", you will also find "437" for a coupe, and I presume "467" for a convertible. These particular marks were made when the body was just a floor; assignment of the "437" or "467" determined which fiberglass panels would finish the car.
If you want to tell us what other marks you found, we may be able to help you figure it out.
[Modified by Chuck Sangerhausen, 7:22 PM 4/23/2002]
[Modified by Chuck Sangerhausen, 8:15 PM 4/23/2002]
For what it's worth, I don't remember my car having any marks at that location, but we may be able to recogize what the numerical sequence means.
[Modified by Chuck Sangerhausen, 8:12 PM 4/23/2002]
Actually, curiosity got the better of me. I went out to the garage, got a flashlight, and double-checked the rear plenum area on my car. Sure enough, there are a plethora of marks. I don't know if I have ever seen these marks before, but I don't remember them and I didn't previously take pictures of them. I expect your plenum marks were originally similar to these, but maybe overlapping as to appear as one long string of characters.
Driver Side: Written "right-side-up" from the rear of the car, the last two digits of the job number "26" (my job number is "426") written in wide white crayon. It appears that the last two digits of the job number were used in the body assembly area (Remember the last two digits that I mentioned under the front right wheel well blackout?).
Very near these marks in yellow crayon is a sharp, thin-lined date , "7-5", which I believe to be the date of manufacture for the fiberglass plenum panel, or July 5, 1970.
In the same area, but in wider yellow crayon and written "right-side-up" from the passenger compartment, is another date "7-22-2". I believe this date has to do with when the rear plenum panel was actually bonded to the body, or when the rear body was built. It means July 22, 1970, 2nd shift. My trim plate shows an assembly "build date" of 7/30/70, which makes 7/22/70 seem pretty reasonable for a body build date.
On the left side of the plenum, written "right-side-up" from the rear of the car are the letters "TC" in wide white crayon. This was apparently written at the same time as the "26" on the right side. I believe these to be the inspector or supervisors initials.
Also, I found some marks, "26 AC", on the underside of the upper deck surface inside the passenger compartment. Again, these are the last two digits of the job number and the reminder mark for air conditioning.
There are also some floor area marks, which I had previously documented, consisting of "437" (coupe) on the right side, and "UA6" and "AC" on the left side. It should be noted that these last marks are written "right-side-up" from the rear of the car, and therefore were in place before the body was completely assembled...it is physically impossible to have done it later after the body was finished.
[Modified by Chuck Sangerhausen, 8:10 AM 4/24/2002]
But, if you have a cure for the common cold, you could drop that info in the mail. :jester
