Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Front end spindle bearing torque....
Old May 5, 2002 | 07:41 PM
Guest
Guest
Posts: n/a
Default Front end spindle bearing torque....
The '67 shop manual calls for 12 ft. lbs. of torque. Since my torque wrench begins at 25 lbs, does anyone have a tried and true method of torqueing the front spindle nuts, without a torque wrench? Thanks, Patrick :D
Old May 5, 2002 | 07:50 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Front end spindle bearing torque.... (FXT)
Smaller torque wrench. :) I tighten the nut tight, while spinning the wheel/tire to seat everything. Then I back the nut off. I then re-tighten it till I begin to feel VERY SLIGHT resistance on the tire. That's where I leave it. Not very scientific, but I've never lost a wheel, or galled a bearing. Chuck
Old May 5, 2002 | 09:29 PM
Guest
Guest
Posts: n/a
Default Re: Front end spindle bearing torque.... (Chuck Gongloff)
Thanks Chuck, I'll give it a spin tomorrow! Patrick :)
BTW, I guess you know you're on "the list" at Troy's 'MUST READ' message for the free homepages, at the top....over 5 mb! :nono:
Old May 6, 2002 | 12:55 AM
SWCDuke's Avatar
SWCDuke
The initial tightening torque is not critical. Just snug the sprindle nut down with a crescent wrench to be sure the bearings are seated. The important part is to back the nut off just enough to get some clearance. With 20 threads per inch, six flats, and two perpendicular holes for the cotter pin, each twelveth turn is about .004", so there is one position that gives you the desired one to five thou end play.
After I've done the initial adjustment I install the cotter pin, but don't spread it, give the wheel a couple of turns then remove the cotter and try to turn the nut one twelve turn with my fingers and reinstall the cotter pin in the perpendicular hole. If it won't go, I had it right the first time.
Duke
[Modified by SWCDuke, 8:57 PM 5/5/2002]
Old May 6, 2002 | 07:14 AM
Chuck Gongloff
Default Re: Front end spindle bearing torque.... (SWCDuke)
I'm "over the limit" !!! Will hit the delete key on a few old pictures. Chuck
Old May 6, 2002 | 06:55 PM
Guest
Guest
Posts: n/a
Thanks for the information, Chuck and Duke! :)
To Front end spindle bearing torque....
