Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Power steering problem - help
Old May 6, 2002 | 10:57 AM
allenz's Avatar
allenz
Default Power steering problem - help
Got a strange problem that I am not sure how to remedy: Just reinstalled the system, and bled it according to the documented GM sequence.
It seems that there is air in the system even after 2 attempts. Not only that but the wheel violently jerks to the left when the engine is started, then it jerks violently back and forth until the engine is shut down.
What is going on??!!
Thanks in advance,
Allen
Old May 6, 2002 | 11:02 AM
JSB69's Avatar
JSB69
Default Re: Power steering problem - help (allenz)
Sounds like your power steering control valve is not adjusted correctly. If you do not have the procedure, it might be on Corvette FAQ.com.
Old May 6, 2002 | 11:06 AM
allenz's Avatar
allenz
Default Re: Power steering problem - help (JSB69)
Thanks, but moving the adjusting nut didn't seem to make any difference. The odd thing is that nothing was changed from when it worked last year. The only difference is that the pump is a rebuilt.
Also, once when we started it, it didn't move; however, when it was touched it took off......could it be a bad valve?
Old May 6, 2002 | 03:59 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
I don't have any experience trouble-shooting Corvette power steering systems, Allen, but it sounds like you still have air trapped in the system. It sounds like the hydraulic hammer effect you have with air mixed in fluids.
The pump is a simple vane pump; highly unlikely in my mind that these symptoms could result from the rebuilt pump. The first thing I would so is double check the hose routing. Trace them out carefully and make sure they are connected to the right holes...the way they are near the control valve, it might be easy to get them backwards.
Old May 6, 2002 | 05:56 PM
allenz's Avatar
allenz
Default Re: Power steering problem - help (Chuck Sangerhausen)
Great call Chuck,
I called the shop and it turns out the hoses were crossed!
The big things went fine; the little ones are killers.
Thanks buddy,
Allen
Old May 6, 2002 | 06:59 PM
Guest
Guest
Posts: n/a
Great call Chuck, I called the shop and it turns out the hoses were crossed! The big things went fine; the little ones are killers. Allen
Allen, glad to hear you got it fixed so easily; I knew things were going too smoothly for you! :lol: Patrick
Old May 7, 2002 | 08:18 AM
allenz's Avatar
allenz
Default Re: Power steering problem - help (FXT)
Smoothly? Well, this should make you feel better, Patrick......We are on our 4th set of calipers, because all the previous set's bleeders leaked! Yes, 4th set...from at least 2 different suppliers.
This is getting old.
Allen
To Power steering problem - help
