Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
'67 Alternator Pulley ID...
Old May 12, 2002 | 09:51 PM
Guest
Guest
Posts: n/a
Default '67 Alternator Pulley ID...
I think I finally have the correct pulley for my 327-350, with no air and no PS. It should be a one piece pulley, with a black phosphate finish, on the left.
The pulley on the right is a two piece, which after a lot of investigation, leads
me to believe it is for a solid lifter BB or SB alternator, depending if the car had PS or AC. Can anyone confirm this? Thanks Patrick :D
Old May 12, 2002 | 11:42 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Default Re: '67 Alternator Pulley ID... (FXT)
Planning to do a little ebaying, Patrick? :D
Is there a part number on it anywhere? I can help you if you have a part number.
Old May 13, 2002 | 11:16 AM
3X2-427's Avatar
3X2-427
Default Re: '67 Alternator Pulley ID... (Chuck Sangerhausen)
Patrick
I believe the pulley on the right is also correct for 65 350 hp applications and my 435 is virtually the same. The one on the left appears correct for your 350 67
jer
Old May 13, 2002 | 09:36 PM
Guest
Guest
Posts: n/a
Thanks Chuck and Jerry :D . Now for my next question. If you notice, the large 2 piece pulley is offset by the fan, on the alternator. This is the position I need to be at, to line up the belt with the outer groove on the crank pulley. The groove next to the engine is reserved for the "water pump belt".
The judging manual states that the one piece pulleys (like the black one) were "offset" to line up with the correct groove. My question is...what do I use to offset the new black pulley, so that it sticks out and away another half inch from the alternator? I need this offset so the belt will correctly line up with the outer groove on the crank pulley. What did the factory use to offset, washers or some kind of spacer? Thanks, Patrick :cheers:
[ [/QUOTE]
Old May 13, 2002 | 10:38 PM
3X2-427's Avatar
3X2-427
Patrick
I BELIEVE you will find that a spacer is listed as a separate part in the catalogs
BELIEVE
jer
To '67 Alternator Pulley ID...
