Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Canister Filter
Old May 31, 2002 | 10:16 PM
9t6t7's Avatar
9t6t7
Default Canister Filter
My 67 has a spin on filter, I am thinking about installing a canister filter for flight judging. Any advise on how its done (hints or problems). Thanks
Old Jun 1, 2002 | 12:40 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Canister Filter (9t6t7)
this is being discussed over on the NCRS site right now :chevy
Old Jun 1, 2002 | 10:45 AM
Guest
Guest
Posts: n/a
This is easy to do. I got the canister from Zip, about $70. Take off the "spin on" filter and then remove the adapter plate up inside, which is attached with two bolts. The canister with the big long bolt should thread up into the tapped block hole, which hopefully is not cross threaded. Be sure to put on the rubber O ring when installing the canister. :D
Old Jun 1, 2002 | 04:53 PM
JohnZ's Avatar
JohnZ
Default Re: Canister Filter (FXT)
And don't forget to replace the spin-on adapter plate with the correct bypass valve assembly and gasket.
Old Jun 1, 2002 | 05:40 PM
9t6t7's Avatar
9t6t7
Default Re: Canister Filter (JohnZ)
After removing the two bolts, does the spin on adapter come off easy or hard. I may do it tomorrow. Thanks for the help guys. Dick
To Canister Filter
