Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Engine Designations
Old Oct 29, 2012 | 03:25 PM
Retired Zip's Avatar
Retired Zip
2nd Gear
Default Engine Designations
Brand new to Corvettes. Retired now and want to fulfill teenage dream.
So,, what does the number/letters of the engines (L88, L89, etc) And where can I find a complete list?
Old Oct 30, 2012 | 08:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The letter and numbers correspond to GM/Chevrolet options beginning with the 1963 model year. Prior to 1963, options were usually numerical. The options list could change from model year to model year. The Corvette Black Book has a reasonably complete list.
Old Oct 31, 2012 | 08:16 AM
gbvette62's Avatar
gbvette62
The "number/letters" your referring to are Chevrolet ordering codes, or what GM called RPO's. RPO stands for Regular Production Option.
When a dealer ordered a car, and the factory built it, the RPO's identified what components were to be installed on the car.
Even though they are considered "option" codes, not everything that received an RPO, was an extra cost option. Somethings needed to be specified in the ordering process, even if they were included in the base car, or considered standard equipment. A good example of this is the L-48 350. Even though it was the standard engine in all 1969-80 Corvettes, it still carried the L-48 RPO.
The first letter of the RPO, identifies the equipment group it belongs to. All engines are "L" codes, transmissions get "M"s, climate control systems get "C"s, suspension packages are "F"s, radios are "U"s, etc.
Here is a link to most RPO's used in the 60's and early 70's. Some of the codes in the list are unique to Corvettes, while some are unique to other Chevrolets, and some were shared by both the Corvette and other Chevrolet models.
http://www.348-409.com/rpo1.html
Old Nov 17, 2012 | 11:16 AM
Roma's Avatar
Roma
I would suggest to search here
http://www.corvetteactioncenter.com/...l#.UKe4SGd8GSo
Every single year and option
To Engine Designations
