Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Need help on my shifter....
Old Jun 8, 2002 | 06:34 PM
topless68's Avatar
topless68
Default Need help on my shifter....
What color paint is used for the two brackets?...tranny mount to frame, and shifter mounting bracket.
Also, I disassembled my shifter to clean the rods, and plates, should I paint these parts, and should I assemble using some kind of lube b/t the shifting plates? :seeya
Old Jun 8, 2002 | 07:53 PM
3X2-427's Avatar
3X2-427
Default Re: Need help on my shifter.... (topless68)
Tpls:
Both brackets are semi flat black. The shifter arms are natural, I apply a heat resistant clear coat, (VHT) and a Litjium grease is what I use between the ears on the shift linkage
jer
PS Major typo : Litjium = Lithium :jester
[Modified by 3X2-427, 7:32 PM 6/8/2002]
Old Jun 8, 2002 | 08:23 PM
topless68's Avatar
topless68
Default Re: Need help on my shifter.... (3X2-427)
You da' man...... :seeya
Old Jun 10, 2002 | 07:33 AM
3X2-427's Avatar
3X2-427
:cheers:
Old Jun 10, 2002 | 03:47 PM
Mac's Avatar
Mac
Jer, we have to get rid of the 'puking' smilie from your sig- you deserve better than that!
Old Jun 10, 2002 | 05:24 PM
3X2-427's Avatar
3X2-427
Default Re: Need help on my shifter.... (Mac)
Ya Think? :D
To Need help on my shifter....
